Help installing xover from Audiocontrol
  • 2
Hi,
I've just installed the 6XS xover to an Orion CS500.5 amp. The 6XS has 8 output channels and the amp has 6 inputs. The 6XS has four channels for the front, hi (from 250 hz and up) and low (90-250 hz). I have a JBL set in front (GTO605C). I've only connected the hi output front channels to my amp (250 hz and up), but i was wondering if i can use a rca Y-cable to connect both hi and lo channels from the xover to the front channels of my amp. What do you think? Could i have problems with the amp?
Thanks
shouldn't be a problem at all.
My guess is that the high output was too high and you didn't have much
bass in the front.
If you want to run 90Hz and up to the JBL's in the front that would work.
It would also allow you to fine tune the 90-250Hz independently from
250Hz and up to get just the right amount of bass up front.
Or you could replace the 250Hz module with a 90Hz module then hi would
be from 90Hz and up.
How many x-over points are there in your system?
Are you just running a sub to 90hz and JBL's from 90hz up?
bass in the front.
That's right. The range from 90 to 250 hz. is missing, and the system sounds incomplete. About the xover points, the settings in the HU are flat and in the amp too, i did this trying to keep it simple.
The subs are in the 30 - 90 hz range, i have a pair of coaxials for the rear channel running from 250 and up and the fron channel 250hz and up too. Like i said, feels like something is missing.
140
444
421
delrice
delrice
Manzanillo, MEXICO
delrice
    Jun 1, 2024
    May 31, 2024
