help i need wireing help..
****, i was not even thinking about running rca's to both sub amps. ok i do have rca splitters so i can run both sub amp from 1 rca.
thanks for the help. theres a lot to learn.
i know the basics but wow there much to this stuff.
what can you set me up with ??
if you like you can pm me with what you have that ill need.
O for got to ask,
what do you guys use on the power/ground wire were it goes into the amp?
My amp is a ppi 1800 is will take 1/0 and thats what im going to run to it. But I dont want to just push the wire into it.
please give link, im not sure what to get, thanks.
O for got to ask,what do you guys use on the power/ground wire were it goes into the amp?
Unless your trying to connect a 1/0 gauge wire to a 4 gauge only port then you could use a 0 gauge adapter to 4 gauge pin, but since your amp accepts 1/0 gauge sticking the wire right in isnt an issue?
Well im useing knu ofc wire. Its oversize and will be hard to just push it in. I have a hard time puting the wire in ring terminals I have. I have to tape the wire up really tight then gingerly twist it in.
could it be done without haveing wire bunch up or fold back, maby.
Im just saying it would be easier to put the wire into something then slip it into the amp.
big scott
blazin low, and loud
big scott
edgewood, md
big scott
