Help getting my pa mid's blend with my tweets
bajbass
81
13
baj
Ok so I have some pa powerbass xpro 6.5 mid's in my door and massive ct-2 tweets in the dash just wondering if it's better to cross the tweets high like 5k or so and just let the mids take care of 5k and down since it was noted in the manual it could play up to 7k I think ...usually I get a better staging crossing the tweeter lower..
just experiment, it'll be different in every car. some cars worked fine with 3k at -18 db, some works great at 8k at -6 db, some worked great at 2.5 at -24 db. Its all dependant on the midrange driver and overall interactions with the vehicle's acoustics. Cookie cutter crossover points wont help you, you need to put in at least an hour of experimenting.
ok i also read some where if u use a 12 db slope on both mids and highs u need to reverse the polarity on the tweets so they will be back in phase at crossover point is that true?
No, that is not true. Changing amplitude (applying a crossover) has no relation to changing phase.
Edit: actually, changing the polarity of the tweet relarive to the mid could create destructive interference, reducing total output.
Sent from my SGH-S970G using Tapatalk
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
634
Are you turning the volume up higher than before or did you adjust the gain or bass boost?
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
961
bajbass
bajbass
baj
Jeffdachef
    Apr 28, 2024
    Apr 28, 2024
