Help! dual voice coil sub, amp and sub have different wiring styles for 1 ohm
Looks to me like the amp shares positive and negative terminals for a mono output. Thats the way my massive is. Id connect it the way the amp recommends, it'll still be a 2ohm load.
Looks to me like the amp shares positive and negative terminals for a mono output. Thats the way my massive is. Id connect it the way the amp recommends, it'll still be a 1ohm load.
He has a DVC4 ohm sub sir.Wired correctly and he should be at a 2 ohm load..If he had a DVC 2 ohm sub he could wire to a 1 ohm load,or a pair of DVC 4 ohm subs..But he states one sub DVC 4 ohm and the amplifier
so the wiring diagram in my amps owners manual should be ignored? that diagram is the opposite of what the amp recommends.
The first diagram shows a DVC 4 ohm sub woofer wiring but doesnt look to me to be correct. I would wire as the 12v diagram as I gave you and connect as the second diagram shows.Though, I would prob call Kenwood Tech support and ask before doing so.It looks to me as though there is a wiring diagram issue from Kenwood.All negative post should go to negative and all Positive post should go to positive.Pretty confusing I know from wiring correctly as 12v shows as in line.
Ive always wired up as 12v has shown and hooked up to a single mono amplifier as your second diagram shows for two ohm stable but you will be at a two ohm load just as well with a DVC 4 ohm sub woofer.Some amplifiers have two connections on a single pole that makes it easier to connect wiring due to excessive wiring and room to place wiring on a single pole of which they have made two poles into a single on the internals
So I called kenwood. They said the diagram with the jumper going from positive to negative will run it at 1ohm. The sub needs to be run at 2 ohms. So positive to positive and negative to negative. Thanks for your help! Would have fried my sub if I ran it like the manual suggested
Now I'm confused... those diagrams were easy... all this additional stuff is hurting my old addled brain... lol
And if you got a 1 channel amp (mono) and 4 speaker terminals... Both + and both - connections are for the single channel
SundayWC
SundayWC
Sooke, BC Canada
shredder2
