JoeSmith502
Beware of Dog!
I have two 2005 RE XXX 12"s that I want to put in my 91 DeVille. The max dimensions I have to work with are 36" Width x 14" Height x 26-29" Deep. I found a box when searching through the forums I was going to try but it is to wide. I like the design and maybe someone could help me come up with one that would fit my dimensions. There is a picture of it below. The specs on that box were:
40Wx13Hx29D
5.3-5.4@28Hz after port displacement, before sub displacement
Port Width-3"
Port Area-70
I didn't take into account any sort of bracing other than the double baffle.
Port width is 3"
First port length is 24.5"
Second port length is 7.25"
If you think a box like this would **** and could suggest a better one I would appreciate it. I like the way it has the ports on the ends. Also never having a ported box before what does the "tuning" part mean? Is that the frequency its loudest at? Also, in the pic it doesn't show the chambers seperated. Are they supposed to be seperate or one big chamber? The amp I will be using is a DD Z1A.
Thanks for the help and I will donate some $ to the person who designs the box that I decide to use.
40Wx13Hx29D
Port Width-3"
Port Area-70
Port width is 3"
