Help Choosing Amp (12" Kicker L5)
bl0ckd
is awesome like Obama.
Subwoofer Specs
12" Kicker L5
dual 4-ohm voice coils
power range: 50-600 watts RMS (300 watts per voice coil)
peak power: 1,200 watts
frequency response: 20-100 Hz
sensitivity: 88.8 dB
Amplifier Choices
VISONIK V318XT
mono subwoofer car amplifier
1000 watt peak output
800 x 1 RMS @ 2 Ohms
400 x 1 RMS @ 4 ohms
Subsonic Filter 20 - 50Hz
Fuse Rating: 25A x 2
Variable Bass Boost 0 - 18dB @ 45 Hz
Frequency Response: 20Hz - 20kHz
THD
SoundStorm SSL 1F850
Force Series Class D Monoblock Car Amplifier
4 ohms: 500 watts x 1 chan.
Max power output: 850 watts x 1 chan.
Tuned Bass EQ (0-18 dB bass boost)
Fixed high-pass filter (200 Hz)
Variable low-pass filter (40-150 Hz)
Frequency response: 9-50000 Hz
Kenwood KAC 9103D
Monoblock Class-D Subwoofer Amplifier
RMS Power Output:
* 500 Watts x 1 Channel @ 4 Ohms
* 900 Watts x 1 Channel @ 2 Ohms
Variable Low-Pass Filter: 50 - 200 Hz
Infrasonic Filter: Off / 15 / 25 Hz
Adjustable Input Sensitivity: 0.2 - 5V
Bass Boost Control: 0 - 18 dB
Fuse Rating: 30A x 2
Signal-to-Noise Ratio: 94 db
Which amp would be best to use, if any? Also, what would be the best way to wire the sub to get the most power out of it?
Thanks!
Subwoofer Specs
12" Kicker L5
Amplifier Choices
VISONIK V318XT
THD
Kenwood KAC 9103D
RMS Power Output:
Thanks!
k.
visonik sux balz
kenwood is made in a portapotty
so I guess out of those ( your only choice is the soundstream)
I'd stil lrecommened this:
http://cgi.ebay.com/ROCKFORD-FOSGATE-300W-2-CH-T3002-AMPLIFIER-5FRT3002_W0QQitemZ250279240633QQcmdZViewItem?hash=item250279240633&_trkparms=39%3A1%7C66%3A1%7C65%3A15&_trksid=p3286.c0.m14.l1318
puts out about 800 RMS @ 2 ohms
bass boost knob
stays cool
BD topology
147 bucks!
Nearly new
I ordered over 6 items already
plus hifiaudio has a great customer support & staff
for under 150 bucks (over 800 RMS)
can't go wrong
amps got 2 40a fuses
all them pop out more power then my fosgate p600.1bd @ 2 ohms (birthsheet 794 rms @ 2 ohms)
beast of an amp, beast of a price@!
bl0ckd
bl0ckd
Fort Wayne, IN
2004SRT4
