I don't think Eclipse makes any smaller mono amps that are stable to 2-ohm, so you would probably be better off with the SVC 4-ohm model if you want to run all eclipse. Otherwise you could use the 4-channel PA5422 (480wrms), or the EA3422(280wrms), with each side bridged to one coil. Or two 2-channel EA2212s (also 280wrms), one to each coil. You would have to make sure you had the gains set perfectly though.
