Help bridging
  • 2
ZoomDaddy
I have an Optimus xl-400 4channel amp. 125wattx4 channel
I have 2 Audiobahn 12's hooked to it regular. 125watt per sub. I have an rca adapter from my back 5x7's because i dont have a cd player yet. just one of those cd-cassette adapters for my personal cdplayer. It all works fine. I just dont know how to bridge the amp. I want the max power to my subs. Can someone explain to me exactly how to do it? Im new at this..
Thanks' //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well if they were dual voice coils at 4 ohms, which most subs are. you would wire the voice coils of each sub together and parallel to amp. This would come out with a 4 ohm load.
each amp has different bridging methods, so read the manual or it may even be marked on the amp of your choice.
the last post wasn't exact
step-by-step details:
the only differing factor is doesn't matter which voice coil you choose as 1 or 2, same with subs
1. run + from channel 1 to + of sub 1, voice coil 1
2. run + from sub 1, voice coil 1 to - of sub 1, voice coil 2
3. run + from sub 1, voice coil 2 to - of sub 1, voice coil 1
4. run - from sub 1, voice coil 2 to - of channel 2 of amp
half done
1. run + from channel 3 to + of sub 2, voice coil 1
2. run + from sub 2, voice coil 1 to - of sub 2, voice coil 2
3. run + from sub 2, voice coil 2 to - of sub 2, voice coil 1
4. run - from sub 2, voice coil 2 to - of channel 4 of amp
115
251
ZoomDaddy
ZoomDaddy
Alabama
soundgy45
    May 20, 2024
    May 20, 2024
