HELP...Amp wont turn on
Miller
Ok I've had this amp for like 6 months and it has always run well....But today I decided to rewire it into a mono 4 ohm load to get 400 rms x 1 @ 4 ohms. It was bumping GREAT for like 10-15 minutes then it just stopped playing. The subs stopped for like 10 seconds then they started up again for like 5 seconds then stopped and now the amp wont turn on. I checked wiring.......WHAT IS WRONG.....I didnt fry my amp did I??? (Amp is the eclipse 33230)
I did wire it to how it was before and the amp still wont turn on....I have 2 25 amp fuses and they look fine but I wouldnt know if the fuse was blown or not
Originally posted by Miller I did wire it to how it was before and the amp still wont turn on....I have 2 25 amp fuses and they look fine but I wouldnt know if the fuse was blown or not
well look at the fuses and if the middle is blown to hell and back then you need to go get a new one and it will work(your amp) i had the same problem wen installing my amp. i checked the fuse and it was blown. i went to radioshack bought two 60 amps fuses for like 3 bux and put a new one in and the amp worked fine.
Wierd...I got a hold of a Multimeter and found out the the terminal where it connects to my battery was corroded and only putting out 3 volts. It's just weird because RIGHT when I rewire my system the terminal at the battery shut off.....No relations to my wiring, yet it happened right when I rewired. And yes, it is up and bumpin again, thanks for the help...later
Miller
Miller
Chicago,IL
bri487
