HELP. All Power in the Trunk Goes Out
jace314
CT
This is really wierd!! I recently wired up my passat with 2 amps. I ran 4g from the battery (inline 100 fuse, rockford) to the trunk where it goes into a dual 60 fuse rockford distribution block. Then 4g to a 1 fared cap, then 4g to my rockford 200.2 amp to power 2 10" infinity's. The other 4g goes right to my alpine 250 amp running my 6 1/2 MB Quarts (x4). All grounds are tight and clean with 4g as well.
Ok so, While my car is running everything is fine, good bass all speakers are clean and things are good. When I start to drive after about 2-3 minutes all power to the trunk goes out? After about 2-3 more minutes I turn the head unit on and everything is fine again but only for a few minutes until it repeats? Like I said when the car is parked but running I can play for hours if need be. Only when I drive I have this problem? Any input would really be appriciated!!!
Thanks!!
when it "goes out" have you actually stopped and put a DMM on the main supply from the batt and the ground and checked voltage?? Checked Ground connections with ohm meter? have you checked to make sure the REM lead is still "hot?" --basic electrical troubleshooting start simple and work your way in to the system making sure each component on the way is "active."
Thanks for the replys! I think I might of figured it out. I forget to mention that I have a small neon tube hooked up, and to have it on when the system is on I ran one of the wires as a ground on the chassis, and for power I conected the wire to the remote lead on the amp! I think the head unit didnt agree after a while of playing and shuts down the remote lead to all the amps and neon. I disconected the cable and drove around playing for like an hour or so and everything stayed on 100%!!
However...What should I do to have the neon turn on when I want it to? I dont want to have it on all the time??
Thanks
jace314
jace314
CT
jace314
