help a guy out :)
PV Audio
The Vision of Sound
hey y'all, i wanna try to start a fiberglass project because it is an artform if done right, and i wanna be able to do it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. so what i need from you all is:
1. materials needed
2. tips and tricks
3. what types of materials should i get (different than number one, i mean like what brand of resin, what kind of fabric etc...)
4. what I should expect from it
thanks before to anyone who helps me out, cause i want this to turn out at least alright //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-dave
I would read the links that aren't dead and then ask questions. Alot of stuff is explained as far as what you will need and ways of applying mat and such. Then start with a small project. Alot of people try to hard at first. You got to crawl before you can run;) I first started playing with fiberglass fixing boat and jet ski hulls. I had the basics, but it was a little different using it in the car audio applications. I took and old sub box i had lying around. Cut out a ring for a sub . Then mounted the ring to the front of the box with some 2 x 4 pieces. Then stretched the fleece over it, and worked out all the wrinkles. This step was new to me, as you don't use fleece repairing hulls //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Then get to applying resin and so on. IT's not difficult to do if you take your time and be patient. Especially this time of year. When it's cold out, resin doesn't like to harden. You have to either mix it a little warmer, or use a hair dryer or heat gun. If possible I reccomend working inside a garage or something. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
are you kidding lemon?
theres a whole entire TWO threads dedicated to this in the box construction forum that are sticky.
it says everything on what you need to know there. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif here. im even generous.
http://forums.caraudio.com/vb/showthread.php?t=36873
http://forums.caraudio.com/vb/showthread.php?t=38665
the second one is "kick panels" but you can apply what is taught there to any fiberglassing project.
dam and he has 10k posts, doesnt he always btich about people not searching
*cries*
sawry, i was at school and not thinking (think about that...............//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif )
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
