Shit, **** ,**** ,**** , I burnt my freakin voice coil so there goes one of the subs,just my freakin luck. why did this happen i had everything connected right and the amp and speakers were matched, can anyone tell me what went wrong? Here are the specs of both.
Amp
ower Acoustik OV2-1600
Super Cool Blue LED
Chrome Top Plate Panel
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio:97 db
THD: 0.02%
2ohm Stable Stereo
System Distress Indicator
High/Low Level inputs With Floating Ground
4 Gauge Power/Ground Connection
Gold plated RCA Connectors
Line output
4 Ohm =310x2
2 Ohm = 370x2
Mono =740
Subs: Audiobahn AW1251SE
12” NATURAL SOUND WOOFER
45 oz. Strontium Magnet
Power Handling: 400 watts R.M.S.
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
Mult-Connect Lug Lock Terminals
I had it wired as in my previous post.
