Heat Unit
  • 2
Usually with Pioneer brand hu's you have to power off the radio, then hold the 'function' button until the radio comes back on. keep hitting the function button until 'aux' comes up on the radio and turn the feature on. Hit the source button to escape this menu, then power on your unit and it should work. Hope i helped.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
498
PSICO
PSICO
mexico d.f.
PSICO
