headunit with no output
Just sounds like the channels on the internal amp went out...the RCA uses a low voltage output and works off of a different circuit
292
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
924
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
924
whojohnjones
whojohnjones
mississippi
outyamouth817
slater
    May 2, 2024
slater
    May 2, 2024
