Headunit rca voltage
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
991
406
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ayork
Ayork
youdoofus
    May 16, 2024
    May 16, 2024
