headunit operating with facial in diff location can this be done?
  • 4
robbie_turner
Dunno if this has been done but I was wondering if there is a way 2 operate my head unit with my facial in a different location 2 my main device. Perhaps there is a converter out there all ready. For ur info I have a Sony headunit. I have made a small diagram 2 help u try and understand what im trying 2 do
cheers
its a bit of a risk then as i have not soldered anything since i was at school and that was many year ago. will the ribbon cable hold enough power for the display and how long do u think this cable can be?
I've heard of someone mounting their deck down by their seat and the face in their overhead console. Thas seems like as long as you could possibly need.
what ^ said. amp gain setting info, test tones are at the very bottom...
417
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
997
robbie_turner
robbie_turner
Birmingham, UK
Rawr-DQ
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
