headunit install
a double din mounting kit
Metra 95-2005B
https://metradealer.com/files/products/INST95-2005B.pdf
more important is the interface between the Bose HU and the Bose amp and due to the Class II Data Bus, you need an adapter to retain chimes and information -
Metra GMOS06
Metra Cadillac Factory Integration Adapter Lets you install a new stereo in your 1996-05 Cadillac while retaining use of OnStar at Crutchfield.com
you'll also need an antenna adapter
Metra 40-GM10
So that's about $150 in parts to install the new HU. welcome to GM.
GM before 1995 is cheap and easy. GM after 2000 is also easy, just more expensive. there is a lot of information in the Class II Data Bus. i have no idea why GM thought that was a good idea.
eaiser to communicate with one another on can bus lines, plus faster data transfer. also if one module goes out in a vehicle, it wont bring the whole network down. class 2 is history now. now its gm lan high and low
jesus. can you not do anything yourself? you got some "bangin subs" you want help with too? you rollin on 24s? you think youre cool? why dont you just google it and research before you drop a bunch of cash on a radio? yes its easy, you go to walmart, find the box that has your cars name on it, pull the harness off the radio and take your walmart harness and match the colors up.
hold on dude i thought forums was to ask questions about things so you get it done right it is a cadillac so i wasnt really sure on the harness thats all why you being a ****** **** about it but whatever thanks for the help for those who did help like keep hope alive and for nateberrier my address is 95 whittenton st taunton mass come here and talk **** but you will just hide behind your keyboard
mloura1981
mloura1981
taunton mass
mloura1981
