head unit
iliveinabox
if i turn up the volume on my head unit to much will it distort the speakers. because ijsut replaced my stock speakers with after market and there getting distorted and i was thinknig maybe i should buy an amp to run the speakers? any input is greatly appreciated
if the speakers you bought are decent and they're still distorting then the head unit's s/n ratio sucks... what h/u is it? you should probably get an amp anyways... its just more fun that way... //content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
Any head unit will distort if you push it past its useful maximum volume. You might stop by an install shop, ask them to take a quick listen and tell you whether it's the normal head unit clipping or a sign of something wrong. Chances are an amp would help greatly.
unless you're going to stupid loud levels, the head unit should be able to keep up and not distort. you might have some noticiable noise but not distortion. models and specs of the equipment would help.
Your HU's amp is probably distorting. Mainly because the speakers RMS is at 60watts and your HU's RMS is at 22watts. The peak on the HU is only at 50watts. So at your HU's peak, you're still underpowering the speakers.
When you hit peak power on an amp, it sends little spikes of voltage up the lines which in turn translate to distortion, and in many cases if these spikes last long enough and happen alot they can cause irreparable damage to the speaker.
Look into getting an amp that has an RMS at around 60 watts up to 85 or so. And that would be to each channel.
what would be a good one. i am terrible at reading wattage. i never know if i am getting amps with to much or to little. ive allready blown three sets of subs doing this. so if someone could find me an amp that could power those speakers and let me know of some good tweeters that would be awesome.
Yeah... what he said...
iliveinabox
iliveinabox
linden mi
kjwiehoff
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
