Head unit suggestions?
Derekmurray169
Been 6+ years since I last looked into things and I'm sure lots has changed in tech.
I generally don't listen to cds anymore and mostly stream through tidal through BT. Would a wired connection be better quality?
I am looking for something with good SQ and decent preouts and eq capabilities what would you suggest?
Also will be adding amp and new door speakers. Possibly a small sub but honestly probably don't need one.
I went with JVC which is Kenwood/JVC. Guys at the shop said they've had some issues with Pioneer quality, but they do sell them. JVC's have been solid. I went with KW-V960BW so I could have wireless CarPlay. The model below that was wired only and should fit your budget. I like the JVC menu system (interface), easy to use and clean. But you may want to go to a shop and play around to ensure you like whatever interface is used in whatever system. Pioneer and high end Sony shouldn't be counted out. Even with what I hear of Pioneer's possible quality issues, they are nice units.
Favorite midbass I have ever used so far is the ML 1800.3. Close second is the yellow-cone polyglass mids from focal. I hate the focal for a 2...
21
80
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
459
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
609
Derekmurray169
Derekmurray169
*******,Ga
tojohnso
    Apr 28, 2024
    Apr 28, 2024
