Head Unit Preout Question
Grimmjoww
Hey guys, bought a new head unit. Its a KMM BT328U, just an entry level media deck. It has 2.5v pre outs. Should I return it and get some thing with 4v? Im just going for a decent little setup with good bass, not a comp setup. Thanks
I'd just set your levels right, make sure the sub level on the deck is maxed to get all the signal you can then set amp levels. I'd do it with the bass knob centered so you got some boost and cut for different music.
Higher preamp voltage is to reduce noise, but you generally don't get noise on the subwoofer channel.
145
548
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
644
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Grimmjoww
Grimmjoww
Tennessee
SilverSquared
    May 19, 2024
    May 19, 2024
