Head unit preamp voltage question
Sir Smoke A Lot
Super noob
I've had my heart set on the new Alpine iDA-X001 for a few months. That is until I saw that it only had 2 volt preamp outputs. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif My last 2 systems both had Eclipse head units with 8 volt preamp outputs. I have always been told the higher the voltage on the HU the better but I don't know exactly what the benefits are. In the end does it really make a difference? What are the benefits of higher voltage on the outputs? Thanks.
Not inherently true.
Potentially a lower noise floor with the higher preamp voltage due to the lower gain setting.
But if you have no audible noise with a lower voltage headunit, increasing the voltage is going to result in zero benefit.
Likewise, if you go to a lower preamp voltage unit and experience no increase in noise floor then you didn't lose a thing.
Remember that the amplifier gain will need to be readjusted for the different headunit in both instances.
See above.
Sir Smoke A Lot
Super noob
Sir Smoke A Lot
Chicago
squeak9798
