head unit okay for subs?
Okay, new to the audio scene. Thinking of hooking up a couple of subs with an amp in the trunk of my car. Can it be done with a head unit such as this? Also, if it can be done - what is a medium quality / high quality set up? Is buying used off of craigslist a good idea or not? What kind of stuff should I look for and what kind of stuff should I avoid?
Just buy a new HU with SUB outputs.. , avoid boss, power acoustic, and stuff like that.. you can get a New Head Unit for cheap under 200$ if not around 100$. If you are just wanting some decent bass and stuff 1 single 12" will work wonders. just do a ported box.
also need to know Budget? What its going in? How much space to sub/box you willing to give up? etc.. etc..
Need to know vehicle and what the stock system is. Lots of people run subs from a stock radio using speaker level inputs from the radio, but some of the fancy factory systems make that difficult.
And budget?
Look at the JVC KD-X40. A lot of people say JVC isn't the best, but that headunit is awesome, for the price. Surprisingly it's the cheapest on Crutchfield.com and you can get it with all wiring harnesses/dash kits for your vehicle for like $100, and there's a coupon you can google to use for $20 off if you spend $100+. So basically you can get a JVC KD-X40 with a harness and dash kit brand new for ~$84. That's what I did.
It has two pre-amp outs so you can hook up an amp for subs in the trunk and also have another pre-amp out in case you want another amp for speakers or something later down the road. It has some EQ controls, not quite as much as high-priced unites (obviously), but definitely a lot more than a stock head unit.
It doesn't have a CD thing unfortunately, but that's fine for me because I wanted a Digital one. It uses like Aux-in, USB, and SD card input. Check it out if your not a big CD guy, great cost for a good head unit!
I would rather have a lower line Kenwood personally...
jvc = kenwood which has helped them a little. new jvc arent too bad.
i would go with one that has 3 sets of 5v preamp outs and still has aux in and usb in front.
If you are just looking to "make it work" yes you can. You will need a LOC to wire up your RCA's to, but that is it. Many people do it with no issues what so ever and it will work 100% fine.
And budget?
Based on the stock headunit hes driving a roughly 90's-2001 Chevy Malibuor even an Oldsmobile cutlass, they're both tbe same body not sure about radio.
this is also another possibility. some amps even come with high level inputs which would eliminate a LOC. i recommend this to many people with newer cars that just want to add a sub because many of them done want to lose the factory radio optios such as nav,xm,voice command etc. also many new stock systems arent too bad and would keep up fine with a small sub addition.
topslop1
topslop1
wallingford CT
keep_hope_alive
Mike Mccabe
