Just making sure... Are you sure your sub is wired like this? jumped wire each pos and negative end connecting each other and one on each pos and negative end connected to the amp?I opened up the box and they ran it parralel, i have 2 negatives and 2 positives, i just tried combining them into one port so 1 negative and 1 positive onto the amp and still it didnt go as high as it was supposed to you can just barely feel the subwoofer vibrate a little bit, the tweeterse were alot louder than it to give you some perspective, if you didn't have your hand on the sub you wouldn't even feel it was on in the rest of the car.
How to Adjust Amplifier Gains Using a Digital Multi-Meter - Knowledge Baseokay, what would i look for with the meter? what would the ideal voltage be?
Thanks for the help, the ground wires are good, and all the wires are good, ima try that tuning thing i guess to see if that is the problem, its getting late so ill update you guys tomorow thanks for the help!Just making sure... Are you sure your sub is wired like this? jumped wire each pos and negative end connecting each other and one on each pos and negative end connected to the amp?
Subwoofer Wiring Diagrams, One 2 ohm Dual Voice Coil (DVC) Speaker
Its
Definitely read that article. YOU DO NOT GUESS WHEN SETTING GAINS. Turn off subsonic filter and low pass filter set to max highest it can go when setting the amp.
For the wire, if you see any end thats a shade yellow/green/gray then its a burnt wire
Check your ground wires. Make sure they are at a proper ground location and that its sanded/scraped off paint leaving a bare metal to metal connection.
Make sure you test your power to the amp as well as setting the gain properly.Thanks for the help, the ground wires are good, and all the wires are good, ima try that tuning thing i guess to see if that is the problem, its getting late so ill update you guys tomorow thanks for the help!
Anywhere but best buy.i tried using that multimeter to tune it and decided to just say **** it and will have best buy install it for me.
Worst place to leave your car for install work. Its like automotive repair and oil changes at walmarti tried using that multimeter to tune it and decided to just say **** it and will have best buy install it for me.
I have worked with the guy at best buy a couple of times in the past and have seen his work, don't get why you guys are saying no best buy, other than car toys my only choice would be hyper audio and if i left my car with them they would strip out all my wire and put in granny wire, just getting a amp, best buy is my only place for that.Worst place to leave your car for install work. Its like automotive repair and oil changes at walmart
Let me just clarify this by adding that you should not give your sub twice its rated power if it's not moving very much. The voice coil will heat up extremely fast if the motor isn't aligned properly to allow the EMF to move the coil and cool it.have u tried pushing in on the cone of the sub. i have had motors shift during shipping due to negligence by the handlers. if motors shifted u could give it. twice rated power and have little to no movement and barely any output.
I gotta give it to you straight man. You are doing things all sorts of wrong if you are looking at peak power and guessing on amp gain settings.Peek power on the sub is 2400 so i would have to find a amo that could give it 5k power, not wanting to spend that money
