hdc318?
Yep, it will work as long as you are calculating the proper port area.
What size port and tuning are you calculating?
Just as an idea, that means you need about 9 cubes and change gross to tune this 6.5
cube box to 38hz.
reread:
did some searching, got few answers. Will hdc318 work good in 6.5 cubes? Thats all room have for sub, port and all. Will have 2000+ watts
Your answer is no, you have room for 2 12's or more than enough for one 15" HDC3 but not 2.
I just got off work and thought about this post. Thanks for replies, but he bought a hdc315 this afternoon
Come back to discuss the box build once he's ready.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
chris at fishercustoms is designing the box, I am building it next week as soon as he gets me the design. He did both my designs and I built a box for a guy with 2 audioque hdc312's he designed also. He does good work
your all set!
this guy will be running a bxi2608d, rated at 2600x1 at 1ohm, but I know it is not that much power
Actually, I crunched some numbers and an HD3C 18 can work in 5.9 cubes net (after woofer and port displacement) using 2 6" areo ports that are 14.1" long each.
This would give you a gross box size of about 6.7 cubes.
05_ZX636
05_ZX636
alabama
mcsoul
