Hdc318!!
  • 5
302yota
my next build will be for my friends 03 f150...and he's plannin on putting an Audioque hdc318 runnin at 1ohm off of a hifonics brutus 1600....the box will be 5.9 cubes at 37hz...with kicker 1/0 gauge wiring kit...here's the box specs from re calculator:
box width= 34"
height= 21.25"
depth= 24
port width= 6.5"
port length= 5.5"
volume comes out to be 5.9cubes at 37hz...
the port and sub will be firing at the roof, the top plate (where the subs mounted)...i was just wondering if this box would work for this sub (considering the port area is about 128sq")....this will probably be the biggest build i've done....although i know the hifonics will be a lil small for this setup but he's on a budget....i'm mainly worried about the box design, and how long the breaking in time is???....once i finalize the box design there will be pics to come
Dude, that's what I'm doing too, and I have kicker wiring. Having the box design will help because someone can tell you whether or not it'll work. 5.9 cub ft should work.
^^^^yeah...right now i'm downloading winISD pro, to see if i can design somethin on there instead of using re calculator....but if someone agrees with my design above, i can go ahead and start the build
his truck is (i guess you would call it an extended cab (but it has four doors) just not like a full size four door
sounds like a Supercab, just like my 2002 F150
302yota
302yota
rockingham, NC
Lakota
