HDC3 wierd noise
How low under tuning are you guys playing these?
Sounds like an over-excursion issue. They can play a decent amount under tuning, but there is a limit before you rip the spiders either off the landing or off the former.
What did you do for your break in process?
Let the car play in the garage for 10-12hrs straight. Usually some old school rap or disco, so nothing that drops low. Every 3-4 hours I turn up the sub level a little more.
After 12 hours I crank em on music for a few minutes and then meter full tilt tones and music. I was trying a few diff copper suspensions and a diff VC config with the alum, so that's why I did so many recones in 3 weeks. Sucked balls...
AQ sells the recone kits and they come with shims, just need to get a CA glue kit if you don't have any.
I run an AQ3500 on each sub daily and haven't hurt a sub yet. One show last year I demo'd full tilt for around 15 minutes straight. I'm sure voltage dropped and I was clipping the shit out of them, but they still wouldn't die, only got a little stinky.
Whats your low-pass and how often are you below tuning?
SSF around 30Hz, LPF = 80Hz. Tuning around 36Hz for daily and I regularly demo Decaf's version of "trunk bang" which drops to 29Hz. EASY hair tricks with that song...
HDC's are very strong subs, but anything can be blown if misused/abused badly enough. I do play below tuning and with a lot of power, but no bass boost and I have a shitload of electrical in my car. Clipping will kill any sub as will over excursion from pushing it too hard way below tuning...
IMOVeCHICKENS!
Firtyfwe here ngz
IMOVeCHICKENS!
727 FLA
mlstrass
