http://www.audioque.com/aq/HDCSeries.htmHow much does a single 12" run, and whats the rms. Ty
Lets not make this a VS threadso those who have experienced the HDC3 and TC 3hp..
which one do you like better?
louder?
sound quality?
Thanks!
ill try to explain. with the sub in box, no power and with it in resting position. i push down on the cone straight, as to not have any coil rub etc. i push it all the way down until i cant push it anymore (using resonable pressure, im not gonna go all out on it of course). about half way through the range of motion the i feel a resistance, and then a couple millimeters (just a guess) it gets loose again, then when i start to ease off the pressure and the sub starts to go back to resting position, i feel th resistance again, then its gets loose. hope that makes sense as to what im talking about.What do you mean by "stick"? Does it hang up or freeze? Does the coil rub? Does it "stick" under power? If it doesn't play it and don't worry about it. Let the suspension settle in and do it's job.
