Hdc3 18 Smaller box for more power?
bgowdy
Heroes are remembered, but legends never die
like the title says. the hdc3 18 already has a box with it, it was mine from before and it turns out the box is smaller then what i thought the first time i owned it. it is 6.01 cubes before displacement, it has 2 6" aeros, the sub and small bracing, and after displacements the box was 5.30 cubes net.
I know alot of ppl will say that small for a hdc3, i was unaware due to i didnt build it originally nor did i even measure it until before when i owned it. well my friends measured it last night and yea it 5.30 cuubes. and power i was only pushing probly 6-700rms on it last year and thats when i got the numbers in my sig.
So im going to be using about 3.5k on the hdc3 18 and i would like to try the same box but im wanting to add alittle more port but that will take the box to 5.16 cubes net which is not that much smaller then the way it sits and im going to use more power. This will geared SPL>SQ
Thoughts? And sorry about the long rant
I've found that larger box gains more than more port area....that's assuming you have 15-17" per cube to start. I wouldn't be surprised if a 15 in 5 cube was louder than an 18
Hmmm... I actually do have 15in per cube. So even with more power? I thought a box csn be smaller then norm with more power? Also it wasnt very much bigger before with smaller ports and way less power.
While a smaller enclosure can increase the power handling abilities of a sub, it is not very drastic in most cases.
However, if you go to large you will drop off on the power handling ability rather quickly.
Thats what i was thinking. Before i had little power and it pretty well
to me atleast. And now it would be alittle smaller but with more power added. Probly more then double what i ran before
How much port was he using?
16^2 per cube, slot port...Peaks around 38Hz...
---------- Post added at 01:33 AM ---------- Previous post was at 01:32 AM ----------
i bet 20"^2
You lost that bet //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
kew. My truck peaks like 50 and im gonna tune around 40. Maybe it work..
258
554
867
698
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
    May 22, 2024
    May 22, 2024
