Decado
Well, since I'm pretty much screwed out of ever getting this amp warrantied because of the whole hccafan fubar, I figure I should look into getting it fixed, if its fixable. The problem I had was that when I first hooked it up and set the voltage and everything it worked fine, then the next day it was alot quieter and I checked the voltage and it was only 9 volts, and turning the gain knob did not make any change. Does this sound like a fixable problem? And if it is, does it sound like an expensive fix?
