Having trouble bridging channel Amp
>>SQL<<
Ok I do not understand what the problem is.
I have a MB Quart PAB 4100
I want to bridge it to 2 channels (200 x 2 RMS)
Sounds simple
I wired the speakers to the outside terminals of channels 1/2 and 3/4 just as the diagram shows below the speaker terminals
Here is the problem - there is no left / right balance
No matter what I put the HU to (all left or all right) it is the same out of the speakers.
It seems to being doing summed mono
I have the RCA's from the HU on to channels 1 and 2
I also tried using channels 1 and 3
Anyone have any experence with this?
May need to check to see if you have a selector switch on back of HU FROM REAR TO SUBWOOFER??//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Just a suggestion
I was using this amp to run my front stage at 100 x 2 and had the rear channels bridged 200 x 1 on a JL Sub
I added another amp for my subs and now just want to run the 4 channel amp as a 2 channel amp for my front stage.
I will have a little bit of time to look at it this morning, hopefully I can figure it out.
figured it out
Need to have 2 channel / 4 channel input switch to 4 channel
Need to have RCA's on channels 1 and 3
Everything works fine now.
Instruction Manual doesn't even cover any of that.
Sounds pretty good, still need to tune everything but getting better and better.
>>SQL<<
>>SQL<<
USA
>>SQL<<
