Having an issue with my system. Somone help me figure it out. Alpine & Zapco gurus
SPLAudioHz
Hey guys, I got my system hooked up tonight.
95 Mustang 5.0 Build Log
So for now I am NOT running a sub, or center channel, or rear fill. I just want to get the front stage set before I add too much. So on my Zapco DC Ref 650.6 I have the symbilink for channels 5/6 plugged in.
To fill you in on my HU, it is a CDA117. After a long chat with Alpine I was informed to switch the switches on the underside of the HU to the side opposite or "Normal" since the Imprint module is where the the amp is getting its info.
I took the left channel RCA for the front and plugged it in. No sound but I figure it is because I need to plug the amp in to my laptop and set gains as the Prev owner did not use those channels.
I plug in the red RCA and I get a rapid popping from my front speaker and the protect light on my symbilink is flashing to the popping. I was like SH|T! Well I figured I may have wired that side wrong (this is a huuuuge maybe because I labeled and rechecked wires more than a dozen times as well as photographed every step), so I swapped the rcas around. The other speakers also did the same thing!!! Well SH|T again.
Anyone have any insight on this? Thoughts, suggestions?
Thanks a ton,
Jesse
SPLAudioHz
SPLAudioHz
Indiana
SPLAudioHz
