juststartin
Can you use a fused dist. Block on your power wires going from battery to amp. Like this... use a 1/0 power lead wire from your battery to your fused dist. Block, then on the output side run your 4 gauge your amp. Im asking because I didn't want to go out and purchase a 1/0 amp kit when I already have everything I need. The fused dist. Block would act as a normal fuse on your power wire, as long as your fuse is large enough, say a 300a or bigger. My battery terminals wont take 2 4 gauge wires so I thouught of this. Please let me know if its ok
