having amp problems, need help fast
you need to see if one of the rca inputs is bad tho .try using one rca input at a time .plug in the right side see how it sounds , then the left side see how it sounds then both .may be a bad rca cord or bad rca on the amp or deck.
You can just run it with one RCA plugged in right? I wouldnt plug in the fucked up one....on the other hand I might just be high. Am I wrong mylows10?
Im not too amplifier savvy when it comes to the technical stuff.
alright guys the same problem started happening again a couple hours after i thought i fixed it. i tried all the RCA combinations i could and nothing fixed it so i'm assuming i have a bigger problem. i'll take it out and get some pics of it later tonight of the insides if anyone could help with that
alright guys so the problem came back after a couple hours so i tried switching the RCAs in any different combination i could and it didnt fix it so i'm guessing i have a bigger problem with the amp. i'm gonna try to take it out tonight and get pictures of the insides and see if anyone sees anything. if anyone else has any idea of what it could be plz respond
jsluss17
jsluss17
Scottsdale, AZ
jsluss17
