Nobody has this receiver? How would I go about in setting up my front speakers for now. Anybody know any website that shows you how to setup home theater. These are the specs of it that I found. I'll take some pictures of it later.
Technical Specifications
36
Audio Section
Stereo Mode
Continuous Average Power (FTC)
95 Watts per channel 20Hz–20kHz:
Five Channel Surround Mode
Continuous average power per channel (FTC)
Front L&R channels:
85 Watts per channel from 20Hz–20KHz,
Center channel:
85 Watts from 20Hz–20kHz,
Surround channels:
60 Watts per channel from 40Hz–20kHz,
Input Sensitivity/Impedance
Linear 220mV/50 Kohms
Front Main In 1.5 V/20 Kohms
Center Main In 1.5 V/20 Kohms
Surround Main In 1.0 V/20 Kohms
Signal to Noise Rate (IHF-A)
Linear 95 dB
Dolby Surround
Channel Separation 40dB
Frequency Response
@ 1W (+0, –3dB) 7Hz–80kHz
High Instantaneous
Current Capability (HCC) ±30 amps
Transient Intermodulation
Distortion (TIM) Unmeasurable
Rise Time 16µsec
Slew Rate 40 V/µsec
FM Tuner Section
Frequency Range 87.5–108.0MHz
Usable Sensitivity IHF 1.3 µV/13.5dBf
Signal to Noise Ratio Mono/Stereo 76/68dB
Distortion Mono/Stereo 0.2/0.5%
Stereo Separation 1 kHz 40dB
Alternate Channel
Selectivity (±300kHz) 55dB
Image Rejection 98MHz: 70dB
AM Tuner Section
Frequency Range 531–1602 / 152–282kHz
Signal-to-Noise Ratio 50dB
Usable Sensitivity Loop: 500µV (MW) / 1500µV (LW)
Distortion 1kHz, 30% Mod: 0.5%
Selectivity ±18kHz 70dB
Video Section
Television Format PAL, NTSC, SECAM
Input Level/Impedance 1Vp-p/75ohms
Output Level/Impedance 1Vp-p/75ohms
Video Frequency Response 10Hz to 8MHz (–3dB)
S/N 65dB
General
Power Requirement AC 230V 50Hz
Power Consumption 54W idle, 700W maximum
Dimension (Max)
Width 440 mm (17.4 inches)
Height 160 mm (6.4 inches)
Depth 459 mm (18 inches)
Weight 15 kg (31 lbs.)
All features and specifications are subject to change without notice.
Manufactured under license from Dolby Laboratories Licensing Corporation.
Additionally licensed under Canadian patent number 1,037,877.
“Dolby,” “Pro Logic.” the double-D symbol and “AC-3” are registered trademarks of
Manufactured under license from Lucasfilm Ltd. U.S. patent numbers 5,043,970; 5,189,703;
and 5,222,059. Foreign patents pending. THX and Home THX are registered trademarks of
Lucasfilm Ltd.
DTS is a trademark of Digital Theater Systems
SDDS is a registered trademark of Sony Corp.
