haha read this
THUNDERBIRD
so this guy that i had a class with is trying to tell me this haha. this is kuz i told him he run 4 gauge for 2 amps instead of his 8 or even 10 gauge for that matter.
Dude, you don't need 4 gauge, I'm telling you dumbass. Look at normal power lines used by a power company, they're often 1/0. twice the sice of four gauge. They carry electricity at about 220volts at several thousand amps. Since electronic flow is directly relative, a wire half the size (4 gauge) would carry half the load no problem, thus 220volts at only a thousand amps. I've got the backround in electronics, and an IBEW electricians assurance, there's no need for 4 gauge. It looks good, and yes, there is slight loss on any wire, reduced by an increase in size, but the loss is negligable.
We use bigger wire than necessary in car audio because we want as close to zero voltage loss as possible. Losing 1/2 volt out of 220 is different than losing 1/2 volt out of 12.
The voltage running between the powerpoles on the street is actuall thousands of volts. It is not reduced to 220 until it gets to a transformer located somewhere near the houses it is being supplied to. The reason the voltage is so high is that if you were to try and send 220 out from the powerplant directly, by the time it arrived at the houses it was intended for, due to voltage drop it would be much below 220 V. Another reason the the voltage is so high is to reduce total amperage being sent through the supply wiring otherwise the wiring would have to be enourmous, much much bigger than 0 guage
i was just going to say the same thing.
lot simpler to send thousands of volts and low amp load through a wire and convert later down the line.... like stated above 220 volts/ 120 volts is only after the power transformer
so this guy that i had a class with is trying to tell me this haha. this is kuz i told him he run 4 gauge for 2 amps instead of his 8 or even 10 gauge for that matter.Dude, you don't need 4 gauge, I'm telling you dumbass. Look at normal power lines used by a power company, they're often 1/0. twice the sice of four gauge. They carry electricity at about 220volts at several thousand amps. Since electronic flow is directly relative, a wire half the size (4 gauge) would carry half the load no problem, thus 220volts at only a thousand amps. I've got the backround in electronics, and an IBEW electricians assurance, there's no need for 4 gauge. It looks good, and yes, there is slight loss on any wire, reduced by an increase in size, but the loss is negligable.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Didn't they teach you Ohm's Law in that electricians' class?
I'm moderately-to-severely intoxicated and even I saw the humor in that //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I would ask for a refund.
THUNDERBIRD
THUNDERBIRD
LANSING, MI
JimJ
