H/U Ground...
i already upgraded all of that, i might relocate my amp ground but it's a very reliable ground.... guess i have to just play around wit the install....
You could try grounding the negative shielding on the RCA to the same spot as the HU, just take a thin bit of wire and solder it to the outer prongs then go to the amp and do the same thing with the other side of the RCA cable by grounding it to the same spot as the amp.
That should kill off any ground loops.
I'm starting to have Alt wine problems i know it isnt' my rca's cuz i just replace those, if i am not able to find a good ground near my HU is it ok to run a ground wire to the negative post of my battery?
the negative post of your battery connects to the chassis of your vehicle. therefore, grounding it to any part of the chassis will be just the same.
yeah i regrounded my amp and found a good place for the hu, i still get a lil bit of whine not as bad as before, i'm goin to find a new ground spot for the engine block to chassis
prioracy
i pack da magnums
prioracy
chicago, IL
prioracy
