grounding..
as long as you have a decent ground from the battery to the chassis to begin with.
Correction. Good negative path to the alternator, which may be through means of the chassis. But not always the best.
regarding big 3. when wiring from alt to the positive of the battery. shouldn't you be putting a fuse between the alt and battery? if your alt regulator goes insane. so does your audio goodies...
Ground the wire between the alt and the battery to what the wire is rated at, not the amps going thru it.
smiley2186
smiley2186
San Diego, CA
Fusion_FREAK
michigan born
    May 14, 2026
michigan born
    May 14, 2026
