Jroo
Is there any advantage to either? In my case I only have the single battery up front. I am going to do the Big 3 with 1/0 and will finally lay cables to the rear to start the system when it warms up. My power wire is 1/0 so I know my ground should also be 1/0. On a smaller set up and a car without a second batter, is grounding from the battery just overkill? Just wondering as I see it most with megawatt systems and strictly SPL guys. Anything that I should worry about or tips if I do decide to ground directly from the battery?
