grounding to a magenetic source
ok, so i ran the ground. it is a very solid connection in my opinion, however, when i close my trunk latch, i lose power to the amp. anyone have anything on this? it works when the hatch is open ....
some of us actually like to know what the problem is ya douche bag
You gave us the problem douche bag, now go ground it somewhere else like a good little boy.
Really, think about it...you think you're going to get a good ground through the trunk lid to the battery. The thing is on hingles then is seperated between the hinges by grease.
Do you really think you're going to get a good ground out of it?
When you close the **** thing it stops working, do you still think it's a good ground?
HMM...
//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
The best ground is to run a wire back to the battery, but the closer you can get to a solid piece of metal that goes up to the engine bay and is grounded to the battery fairly well, the better off you are. //content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif
rawr...what part of FL are you in?
Fort Myers, it's like 2 or 3 hours south of tampa.
ok ok, i'm not retarded enough to ground to the actual hatch. jesus.
its the latch that catches the hatch and holds it shut. When I posted this, I already had it grounded elsewhere and everything works fine. I want to know the technical reason why this will not work!!! Anyone can provide a "ground it somewhere else" or "ground it the best way" answers. I want a little more technical detail for future installations.
This is where it was grounded. under the latch around one of the bolts.
suparunna2000
suparunna2000
Hoboken, NJ
Rawr-DQ
