Grounding an amp
Andrew_as
I am putting a second battery in. It is a batcap 2000. I plan on using my 0 gauge wire from the front battery to the back one for the positive. Than ground the battery in the back somewhere. My question is should i ground my kicker 2500.1 and 350.4 to the second battery or should i ground them to the frame where i ground the second battery?
battery, thats how i have mine setup. i might eventually run a ground from front batts/alt to rear batts, but just ground the batcap 2k to the frame and run your amp grounds to the batcap 2k.
If you still have low voltage issues at the amp after this then consider running a dedicated 1/0 negative from front battery.
Andrew_as
Andrew_as
Topeka, KS
jrwalte
