Ground Wire Help
if you were having a ground problem, the light on the amp wouldn't be lit.
You have another problem. Ohm load, under voltage, over current, physical damage, etc...
i'm not sure i see the problem. you ground the amp and it turns on. do you mean the protection light is coming on? what kind of amp is it and what are you powering with it? as mentioned before it could be going into protection due to an ohm question
Dougefresh
Dougefresh
Stafford, Va
ANeonRider
