ground wire help
i actually have 3 in questions:
1) ground connecting 2 HC2000 bats (about 1 ft)
2) ground from 1 of the extra bats in the bed of my truck to the main bat in the engine bay
3) ground from amp to extra bat (3ft) and power is about 3ft
i actually have 3 in question:
If you're wiring up batteries, I would most definitely suggest 1/0 all around.
x2
i thought you were talking about running power and ground from the starter batt to an amp somewhere a way from it
for batts, use the biggest you can fit.. for runs that short, it wont cost that much for using 1/0 all around, and it **** sure wouldnt hurt
thanks. another question: i have 3 ground leading toward one of my extra batteries. 1 is from my 2500.1, another is from the other extra bats, and the last is connecting to my original bat in the engine bay. question is, should i route all of those to an unfused distro block and then to a bat terminal or should i just snag one of those terminals that support 3 runs of 1/0 from knu?
dannyz122001
dannyz122001
Baton Rouge,LA
dannyz122001
