Ground straight to the battery?
HK2k
I was just thinking that with as much time and money as people spend to correctly set up an electrical system, is it at all better to run the ground wires from the amps directly to the negative terminal of the battery? It wouldn't be that much more work than grounding to the frame of the car, and it seems like there would be less resistance. Any thoughts? Thanks.
I dont know why but my tach is the only thing i hooked up to the battery ground and one night it messed up. I hooked it up to the block and its been fine since.
no idea why.
pretec
I actually asked this question a while ago. Anyways, everyone's response was it didn't make a difference one way or another. There are some pros about directly connecting the amp to the battery though. There is less interference with the freqs... this only makes a difference with cb/ham type radios though. There isn't as much of a load put on the bat -> ground wire. This doesn't make too much of a difference unless you plan on running an insane amount of amps. Anyways, most of the electrical problems are because of low amp alternators. However, I just went ahead and spent the extra 10 bucks or whatever and ran a neg wire to my bat :) I'm running 160amps through my two amps though.
you kidding me? your vehicle's electrical system is a circuit...all current flows through every point in the circuit unless something's shorted out. The battery's ground is extremely important, which is why it's part of the "magic three" to get upgraded to a larger gauge when it comes time to.
it comes down to resistance. We know wire of a given gauge has a given resistance per unit length. The question - which no one here knows the answer to - is -- Which is less resistive, the wire, or your car's chassis?
My sources say the answer is a car's chassis, others claim it would be the wire.
Most of you will be quite surprised at the resistance in the ground return using the car's chassis. 99% of installers never check this most important connection. Always make sure you check it and sooner or later someone just might add this important fact to the big 3 wire upgrade.
It's also cheaper to ground to the chasis, saves on the amount of wire needed.
But if the money isn't an object, and u like long grounds, then go for it.
JUST make sure ALL your wires arent exposed..... LONG story
Noise resistance. That's about the only reason to do it.
I think this topic has been covered elsewhere on the forum //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you ground straight to the battery, he is correct, the current that flows through the amps' power and ground will not go through the battery ground. That is the point of the direct battery ground. You bypass the chassis and battery ground and give it a straight shot. My amps are grounded that way, FWIW.
HK2k
HK2k
Denver, Co
forbidden
