Ground Resistance reading
Make sure you subtract the resistance from whatever you are using to get to the batt negative as well, I can't imagine it would be that much but...
I read I was supposed to touch both leads then subtract that from my reading but I didn't get a stable reading from both leads, so what do you mean by the resistances I'm using to get the battery negative exactly?
is it hooked up to your amp already? if so make sure your ignition is off. if power is flowing through it then that would make a difference.
Yes its hooked up to the amp, but the ignition was OFF when tested.
---------- Post added at 07:53 PM ---------- Previous post was at 07:52 PM ----------
my cheap dmm would read stupid numbers like that but borrowed a buddys fluke meter and they all zeroed out on his. perfect grounds FTW. get a good meter or you will be guessing. hence this thread.
What price range is considered a good meter?
I read your OP that you were using another piece of wire to go to the negative battery terminal, subtract the resistance of any wire that is not a normal part of the circuit.
Oh makes sense, how do I figure the resistance of the wire? I just used some extra Cadence speaker wire I had laying around.
Just measure it, that will give you your total added resistance that isn't normally there. You're grounds are still likely high, but you may drop several ohms depending on the size of wire you used.
I don't know wire generally doesnt have much of a resistance unless you run AC through it. I could be wrong but if you are truely getting 22.4 ohms, I dont think the other components are adding that much more resistance. But I would measure anyway just to be sure. If all else fails, I ran my ground back to the engine block, this works great
Well I can do that, or I could just ground it directly to the battery ground correct?
Did you say you have washers between the ring terminal and metal? Don't. Any washers are on the outside between screw head and terminals. Terminal should be touching metal directly.
Bolts are superior to screws for grounding, IMO
When I measure grounds, I use a resistor in series with my test lead. Some DMM's are inaccurate at low resistances. 10 ohm resistor would suffice. Measure lead/resistor first, then measure ground path with lead, then subtract for difference.
Note also that how well the DMM leads are touching will affect results. Oil from your hands can increase meter lead resistance. Clean the leads.
[quote name='keep_hope_alive']Did you say you have washers between the ring terminal and metal? Don't. Any washers are on the outside between screw head and terminals. Terminal should be touching metal directly.
Note also that how well the DMM leads are touching will affect results. Oil from your hands can increase meter lead resistance. Clean the leads.[/QUOTE]
1. yes I do have washers between the terminal and metal, I'll remove them tomorrow.
2. I figured so but I just haven't bothered since I had the screws, I think if I use bolts I'd rather do it to frame
3. I touched the leads together and got some funky reading (wasn't stable) I never knew that about oil from hands I'll clean them and try again, thanks @keep_hope_alive
VisceralSound
VisceralSound
Rochester, MN
VisceralSound
