ground noise from intrepid
woodydh
I just finished installing the door and rear deck speakers and the sub. I have 4 ga. power and ground running to a MTX 4405. The ground is bolted to a bare metal surface under the seat. The problem is, when the key is turned to acc. everything is fine, when you start the car, you get a nasty buzz sound out of the all the speakers except the sub. I changed grounds twice, once on the seatbuckle bolt and now on the floor under the seat, I sanded the metal and bolted it down. I have Monstercable RCA's with the ground on them and that is connected to a piece behind the dash. I am totally lost, any help would be much appreciated!
I got it! I did as you said, squeak. I disconnected the RCA ground, and the that didn't change it, so when I disconnected the HU, the little spade plug for the ground fell out of the plastic main plug. I don't think it was ever making contact. Plugged it back in and all works fine. Thanks for the help from all!
woodydh
woodydh
GR Michigan
woodydh
michigan born
    May 14, 2026
michigan born
    May 14, 2026
