Ground Loop or bad RCA's
Hybrid90accord
Ok here we go well I have a pioneer ddeh-p8600 headunit for 6 months and I love it. I'm also running a PPI 2 channel , Audio control X-over and Jl 5001. I went to pull out my old RCA and replace them with some new monster cables RCA's and now I have engine wine and poping when I turn the car off coming out of the speakers and subwoofer. I put back the old RF twisted RCA and I still have the wine now. Is it coming from the headunit? I don't understand how all of a sudden I have engine wine. I put a ground loop isolator to the RCA's and It was still wining through the speakers etc. What in the hell am I to do. I sent the radio off to get serviced but i'm not even 100% sure it was the radio. And Ideas, the power and rcs are on different side of the car like their suppose to be.
try re-grounding amps. ground all amps to the same spot and make sure it is a good ground. also i use to get slight whine with my 8600, so i grounded it directly to the battery using 12 guage wire and i had no noise at all.
What we used to do at the shop for noise was ground the outer shield of the RCA's. It was a temporary quick fix or a bandaid for noise. It worked 60% of the time. Try doing that, it's a very inexpensive fix.
Another quick solution was to ground the amp all the way back to the battery's ground. This way you don't have different level of voltages in your system, which is cause of noise.
A bad alternator could also be the cause of noise as well.
We use Rf rca's at my job all the time, and they give us alot of problems so that's why i went with the moster cables cause i've never had a bad experience with moster cable personally. some times the Rf's work and sometimes they don't
the car i have all my music in is my 03 mazda bough brand new. I replaced the battery with a optima yellow top, what are the chances in your opinion of the alt. on a 03 going out so soon in your opnion? Is that covered in the factory warranty? I only have 30,000 miles on the car
Very slim chance, I was just throwing that out there because bad diodes in an alt happens. Since your car's new, most likely not.
There are more types of noise eliminating units out there too like ground loop isolators and noise filters on the power wire of your HU.
It was the radio, I got it back from service today i hooked it up today along with my new alpine 4 channel and new 8002 and it sounds great no noise just crystal clean music.
Hybrid90accord
Hybrid90accord
Atlanta
Hybrid90accord
