Ground Connetion starting to corrode
It is clean of dirt and grease at the time you actually make the connection. You apply the grease or spraypaint after you connect the ground. This seals the connection and prevents the corrosion from re-occuring.
What Kind of grease should I cover it in? And should I disconnect the negative battery terminal before doing it or does that not really matter?
JeffM
JeffM
NL, Canada
yunvme666
vegang
vegang
