gross trunk space crown vic?
If you did full fiberglass and used the whole trunk, spare tire space included, as an enclosure.. probably 8-10.
Ask a random Crown Vic driver to measure their trunk.. lol.
Id measure mine if the heavy *** 18" box was not in their, lol.
In the "well" or "pit" in the middle, its around 10 to 11 cubic feet of usable space. That still leaves the shelves on the sides and the space under the rear deck.
thats what i was thinkin... i thought 8 sounded a little small for what i had seen. So 2 18's with a little bit of creativity would not be a huge issue?
The biggest box you can fit in that well space is probably about 9 cubes if you used Aero ports. If you used a slot port it would probably be closer to 8 max after port displacement.
i got 9 cf the most and yes i have a vic and a marquis
RAB hit the nail on the head, he should know, hes changed setups enought, lol.
And yea I have a Crown Vic, a 04 to be exact //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i figured you had a vic based on your response... do vics follow the standard sub back port back setup like most trucks, because i see alot of sub up port back in vics
spencer321
spencer321
palm bay
Crownvicon28s
