ok I got these subs last week. They are 2 12" MTX subs in an enclosure. They are both 200W 4 ohm(written on the subs themselves). Here is a link to them: http://www.crutchfield.com/S-muwcyfSRWdf/cgi-bin/ProdView.asp?g=510&I=236RT12X2A
Here is the specs on them(on a sticker on the sub box):
- 400 RMS Power
- 800 Peak power
- 4 ohm nominal
- 92 db @ 2.83/1m
- 48 - 150 Hz
I was recommended this amp:
http://www.techronics.com/index.cfm?fuseaction=product.display&product_id=120&gc lid=CLeZ7__o_4kCFShSPgodax6rSQ
Someone else is offering me this amp for $80:
kicker zx300.1 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17035
I'm not sure if the speakers are in series or parallel. I think they ar in parallel. Only one sub is connencted to the point where i would connect the amp. One sub is wired to the other at both + and - then the wires go from that sub ( the one that the other connects to) to the point where you hook up the amp.
Can anyone help!?
- 400 RMS Power
- 800 Peak power
- 4 ohm nominal
- 92 db @ 2.83/1m
- 48 - 150 Hz
Can anyone help!?
