njknittle 10+ year member Senior VIP Member 386 0 PA May 19, 2012 #1 I have two sundowns 2ohms each and a t1500bdcp, its a two channel amp. How to hook it to both subs? Click to read more...
Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland May 19, 2012 #3 are the subs single 2s or dual 2ohm??
OP njknittle 10+ year member Senior VIP Member 386 0 PA May 19, 2012 Thread Starter #4 Why does it have two channels?
av83 10+ year member CarAudio.com Veteran 3,121 1 Midwest May 19, 2012 #5 Why does it have two channels? Click to expand... A lot of mono amps have two terminals... but they are for the same channel.
OP njknittle 10+ year member Senior VIP Member 386 0 PA May 19, 2012 Thread Starter #6 two dvc sundowns 2 ohms
Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland May 19, 2012 #7 Rockford Fosgate® - RFTECH Support
OP njknittle 10+ year member Senior VIP Member 386 0 PA May 19, 2012 Thread Starter #8 i have it so its hooked up at one of the channels pos and the other channels neg
Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland May 19, 2012 #9 use that for wiring diagram
OP njknittle 10+ year member Senior VIP Member 386 0 PA May 19, 2012 Thread Starter #10 everything is hooked up right but the subs themselves sound weird now.
Falcons 5,000+ posts that **** i dont like 5,736 75 Albion, New York, United States May 19, 2012 #11 hook them up in series/parallel. all done. you will see a two ohm load
av83 10+ year member CarAudio.com Veteran 3,121 1 Midwest May 19, 2012 #12 wire your subs in a series, then one to each terminal.
Skinkutter 10+ year member Member 31 0 United States May 19, 2012 #13 I think you gave him the wrong link. This one is the box calculator.
D des343 10+ year member CarAudio.com Elite 1,015 1 Kalamazoo, MI May 19, 2012 #14 its a mono amp....it doesnt matter as long as your negatives are in the negative spot and the positives are in the positives spot
